Save Dialog Lock Up
Has anyone run across an issue with the "save as" dialog in Labview? Occasionally, if I linger too long on the "save as" dialog, LV starts to search for something and hangs (see attached). There is nothing I can do but kill LV. I've tried hitting stop and it does nothing. The search dialog is modal, so I can't select anything in the "save as" dialog. The only work around I've found is to be quick about selecting what I want to do within the dialog.
I'm currently using LV 2013 sp1, but it was also an issue before the service pack.
(3,100 Views)
Thats a known issue resolved in the latest TSVN Toolkit release.   Update the toolkit.
(3,091 Views)
I never would have thought of the TSVN toolkit as the source of the issue. I've upgraded it now. I'll see if that fixes the issue.
Thanks!
(3,074 Views)
More on the issue
And I would not have eitherSmiley Wink
but the loading display was awefully familliar
(3,066 Views)
