Save Digital Data to a Text File
I have digital data collected from two ports simultaneously as N number of samples in waveform that I do calculations on to get a result. I would like to save the raw data in a text file so that it can be easily viewed in an external program, like Excel.  This file would be used as verification of the result calculated in my program. I would think this would be a simple thing to do in labview but as yet have not figured it out. I’ve tried to change the digital to analog and then save as a text file but the data no longer gives the same results when recalculated in an external program. Thanks for any input on this subject.
Tessa
Message 1 of 15
(5,584 Views)
Did you try the "Write to Spreadsheet File.vi" in the File I/O pallate?
Message 2 of 15
(5,578 Views)
If you have and it didn't work, let us know the exact data type of the raw data and how you wanted it to be formated in a file.  For example, is the data booleans, integers, doubles and what are the array dimensions etc.  There are lots of options as how to do this.
Message Edited by paulmw on 11-16-2006 07:40 AM
Message 3 of 15
(5,557 Views)
Tessa
Try Export Waveforms to Spreadsheet File.vi in the Waveform I/O Palette.
David
Message 4 of 15
(5,557 Views)
The write to spreadsheet file only excepts values of double precision and even when I extract only the Y component of the waveform it gives a broken wire. I would still need to convert from digital to analog.
Tessa
Message 5 of 15
(5,555 Views)
I am doing a Digital 1D Waveform N Channel N sample read with DAQmx of two different lines. The output is a 2D array of waveforms. I separate the two lines with a pair of Index array VIs then extract the Y-Componet to search for the index where my event happens and complete my calculations on that.
Tessa
Message 6 of 15
(5,537 Views)
The Export to spreadsheet VI is only for analog waveforms not digital, I too thought I could just convert from digital to analog and use the Export to spreadsheet VI, but I didn't get the same result from the external program, ie Excel.
Tessa
Message 7 of 15
(5,535 Views)
Which version of labview are you using? There are more functions in 8.0 above that should be able to help you.
Also, can you post your code or at least a jpg of your block diagram. I would like to get a better picture of where you are at the moment.
thanks
David
Message 8 of 15
(5,528 Views)
I am using 8.20.
Thanks, Tessa
Message 9 of 15
(5,520 Views)
OK thanks for that. Could you do this for me now?
1. Populate a Digital Waveform Control with the data you are trying to save.
2. Cut and paste the Digital Waveform Control with the data into a new vi.
3. Right click on the control and Data Operations -> Make Current Value Default
4. Save the new vi and post it.
This will give me data to work with.
thanks
David
Message 10 of 15
(5,514 Views)
