Save File Automatically
Dear Sir
            I tried to save file Excel automatically with timing name, but still not work.
            Anybody can advise me, how to solve the problem.
Thank you.
Message 1 of 8
(4,260 Views)
Hi pic,
  1. Don't use the colon (":") in filenames…
  2. Provide a folder to BuildPath function…
  3. Debug: Which error do you get?
Message 2 of 8
(4,238 Views)
As usual, GerdW's eyes are sharper than mine.  I was looking for the Colon that Gerd mentioned, and wondering why you didn't specify a Folder when you built your path name.
I really dislike using Date/Time as the basis for File Names -- it is "User-UnFriendly", in my opinion.  I notice that you realized you can't save the date as 19/jul/22 (and used 19.jul.22), but you also can't say 08:39 for the time, but can say 0839, or 08,39, instead.
But why not use a less confusing name?  If time-of-occurance is an important parameter, save it in the file.  A format I often use is a short name ("Expt-5") followed by sequence numbers in a fixed format (e.g. "Expt-5 003") with an appropriate trailing extension ("Expt-5 003.xlsx").  Note that LabVIEW does a pretty good job knowing that the last dotted name-part is the Extension, so you could also name it Expt-5.003.xlsx.
Bob Schor
Message 3 of 8
(4,184 Views)
I admit it can be a little long but I really like using the Date-Time in my filenames.  I usually go for: XXXXX-YYYYMMDDHHMM.xxx where XXXXX is my serial number, test iteration or whatever and .xxx is the appropriate extension.  (Pardon the watermark but I'm still waiting for management to license my LabVIEW.)
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 8
(4,158 Views)
To the tune of "You Say Po-tay-to, and I Say Po-tah-to"
   You like Long File Name, and they all have Dates,
   I like Short File Names that Have what it Takes,
   Long Date Names, Short "Takes" Names,
   No Fake Names, or Nick-Names,
   LabVIEW Brings the Whole Thing Off.
Bob Schor
Message 5 of 8
(4,145 Views)
Smiley Surprised Smiley LOL
Bob, I think you've had too much or too little coffee today...
Message 6 of 8
(4,134 Views)
Coffee?   Or something...
Smiley Wink
Anyway, I often embed date/time info into filenames for a lot of the test stations here too.  Most fixtures create filenames based on test metadata plus YYYYMMDD_HHMMSS timestamp info.  Then multiple runs on the same UUT can still end up with unique filenames that can be sorted with some rationality in Explorer.  (And filesystem timestamps do not necessarily stay constant, such as when users post-edit a file to fix some header info they forget to enter correctly before running the test.)
-Kevin P
Message 7 of 8
(4,120 Views)
Thank you every body, I got it.
Message 8 of 8
(4,110 Views)
