Neal,
Property Node->Front Panel Window->Panel Bounds
can give you the panel rect, you can add/subtract edges (fixed number) to get the rect you want, even if user moved the window.
There is a new VI (SnapView XP, LV7.1) in G Toolbox (http://gtoolbox.yeah.net) to capture a window without specifying rect:
"Capture the specified window (even if the window is outside screen boundary, or convered by other windows), and save to the specified path. Support bmp, jpg, gif, png, and tiff file format.
Require WinXP."
No additional installation needed if you build your application (with my VIs) into exe.
No extra cost for distribute your application (built with my VIs) unless you make massive distributions (thousands of copies).
You can always get one more license to make more distributions.
George Zou
George Zou
