Save Roaming Data of Starter kit 0.2 in Text file_ Error 43
I want to save the ultrasonic data (distance&angles) of the Starter kit 0.2 Roaming program in text file. When I run the program the dialog window to set the text file doesn't open (canceled automaticly by the program I think !), when I stop the run Error 43 is shown (because the dialog is closed without selecting text file).
Does any one has a solution how to solve this problem or any solution to save this data under any format (.txt .xls ...) ?
Thx
(3,010 Views)
Thx
What Starter Kit 0.2 ?
(2,987 Views)
Sorry, it's Starter kit 2.0
(2,974 Views)
I don't get around much, but what is a Starter Kit 2.0 ?
(2,970 Views)
NI robotics starter kit 2.0 a robot equiped with sbRIO 9632
(2,964 Views)
