Save VI developed in Labview 6.1 to work in Labview 5.1
I have been working with Labview 6.1 but I need to execute my VIs in Labview 5.1 too. What can I do to reuse all the VIs without having to develop them again in Labview 5.1? I am not able to save my VIs as 5.1 from Labview 6.1 It only allows me to save them as Labview 6.0
Thank you!
(2,749 Views)
Assuming they can be converted, and there's not too many, you might want to try posting them here for someone to convert. (convert to 6.0 first and zip) Not too elegant but may get you out of a bind.
(2,749 Views)
Yes, each new version of LabVIEW only carries the capability to save for one version previous. So, you would need to save the 6.1 VIs for vesion 6.0, and then from LabVIEW 6.0 save for 5.1. If there aren't too many VIs, one of our engineers here would most likely have no problem with making the conversion for you. You could email NI with them to make it more private, if you'd like, rather than posting them on the site. (To create an email request, go to www.ni.com/ask).
Hope this helps!
Liz Fausak
(2,749 Views)
