Save a front panel image problem
Hi, i'm trying to save at run-time an image of my front panel, and the little code with the Invoke Node (FP.GetImage) works well but there is a problem, i have a background image for my front panel and this image don't show up in the image saved so i have an image with controls and graphs but a blank background. Is there some way to obtain an image of my ENTIRE front panel? Thanks
(3,245 Views)
I found a thread similar to this here:
http://forums.ni.com/t5/LabVIEW/FP-Get-Image-method-does-not-capture-the-background-image/m-p/775191...
TailOfGon
Certified LabVIEW Architect 2013
(3,218 Views)
You can use the code capture tool to grab the FP image as a whole. Use the low level vi's of code capture tool (Courtesy :
(3,213 Views)
Here's how I got ride of tghis issue, I use Windows "printscreen" function by simulating a keyboard stroke and then I get the data from clipboard (crop it it necessary) and save the image.
What I like about it is that the "crop" makes it easy to get just what I want when there's more than one monitor.
What I don't like is that it's a windows only solution.
Hope it helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,198 Views)
