Save a log file in CompactRIO 9048
Hi, everyone!
How am I to save a log file of a Labview's program in SD card or pendrive conected in a CompactRIO 9048? I have a program developed in Labview installed in Windows 10.
(868 Views)
Hi marvin,
You use the very same file functions as you would use on a standard Windows LabVIEW program!
You just need to change the file path to point to that drive. (The USB thumbdrive typically is mapped to drive U: on a Linux-based cRIO…)
(854 Views)
