Save & Read Control Cluster Error
I am trying to debug  a vi (attached). The attached vi read  control values that were saved at the end of prior vi run. The problem is that all control values are read and set with the exception on one - the camera cluster control; the vi throws an error while attempting to  set this control. What might be causing this problem? A copy of saved xml file is also attached.
(2,585 Views)
Hi aderogba,
I downloaded both your VI and xml File and I am unable to reproduce this error.  Do you get this error when you are running this VI alone or when you run it within another VI?
Kira T
(2,556 Views)
