Save an image when clicking a button (with a numerical filename)
Hi again
Ok I found it, sorry.
How can I adjust this code so that I can save pictures while I'm running the program? So if I click that button 5 times, it creates 5 different pictures.
Message 11 of 15
(1,213 Views)
Hi you can learn a lot by studying the NI standard report VIs. Take a dive into the code for the VIs I have marked with red circle. Just remember to use the "save as" option then saving so you do not overwrite the original.
Message Edited by t06afre on 04-20-2009 01:37 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 12 of 15
(1,210 Views)
986521345 wrote:
Hi again
This has already been answered several times. Use a shift register to keep track of a counter. Each time you click the button increment the count. Append the count to your filename.
Message 13 of 15
(1,197 Views)
you should really take advice! (Like smercurio: the answer has been given before...)
The time format you use only includes hours and minutes, but no seconds or parts of seconds. Include them and you will have no problems... (Hint: use the format string I gave in one of my earlier posts!)
Message 14 of 15
(1,187 Views)
Indeed. With seconds included as part of the filename you won't even need to use a counter, as it's unlikely you will be pressing the button multiple times each second (unless you imagine yourself waiting for an elevator and the button is already lit). Smiley Wink
Message 15 of 15
(1,179 Views)
