Save and load controls or indicators
          Is it possible to save and reload the controls or indicators using ms access? not the controls or indicators values . Any detailed example pls do share?
Message 1 of 23
(4,609 Views)
Hi jay,
What exactly do you want to save/(re)load?
Message 2 of 23
(4,604 Views)
Why do you want to save them in access first? I am not really clear when you said you don't want the values but the controls/Indicators. Are you trying to create controls/Indicators dynamically in a VI?
Message 3 of 23
(4,602 Views)
          For example in case of a parent and child windows. In this save all the child windows and reload whenever needed? for example for restaurant cash systems.
Message 4 of 23
(4,593 Views)
Hi jay,
so this is a continuation of your older thread? Why do you create double posts?
SubVIs are VIs. You can save them as any other VI. When you want to save settings/values used in those subVIs you have to save them in files (or databases) on your own…
Message 5 of 23
(4,586 Views)
              I reposted because i didn´t get a proper response. I know sub vi are vi´s but,  i'm using many clone of a single subvi. So, i can't able reproduce those clone vi's with their properties.  If any detailed example pls post it.
Message 6 of 23
(4,552 Views)
Hi jay,
because you don't like the responses you got you started a double post? Shame on you!
Which properties are you talking about?
Message 7 of 23
(4,544 Views)
I am still trying to understand your problem, help me out. Are you trying to populate the same data into different clones of a same sub VI? Please explain clearly the issue you are facing.
Message 8 of 23
(4,543 Views)
thread continued here.
Bill
CLD
(Mid-Level minion.)
Message 9 of 23
(4,520 Views)
            For ex: I have a knob indicator, its measuring a temperature or some pressure of some device_0. So, i create a new clone of the know with temperature or pressure 2 and same continues for 10 indicators. So, i want to save all those clones in a data base or a file.  And if i use  device_0 after few days,  i don't want to create again, instead i want to load from a file. I hope now u get the point.
Message 10 of 23
(4,510 Views)
