Save control\Indicator properties into .bin file
Hi All,
1. I want to get all the properties of the indicator\control and save the same into the bin file.
2. And i want read these properties in another VI.
For the first point, is there any way to save all the properties like, font size, position, bounds and etc. Or i should get all the properties by using property node for each property?
And with the second point, I am able to do it, no issues with it.
Any help is appreciated,
Yogesh
(3,542 Views)
Hi
The easy way is to make your controls/indicators as typedef / Strict typedef.
Silver_Shaper | CLD
(3,530 Views)
Yes, making typedef will copy the properties, but i want to get the properties with the monitor resolution set to different values. I want my application tobe used at different monitor resolution. So, I will save the control, indicator and decoration properties, save it in bin file. Wen the screen resolution changes apply respective properties and th UI looks fine.
So, I need to save the properties into bin file.
Yogesh
(3,526 Views)
Hi what about vi properties windows size option are you checked it out?
Silver_Shaper | CLD
(3,523 Views)
Yes this is also an other option. But sometimes, the controls will overlap and results in messd-up UI.
So I opted this option.
Any other way of doin the same guys?
Thnaks,
Yogesh
(3,509 Views)
(3,474 Views)
