Save data in .xlsx file
In my application I want to read a .xls file and  copy the file to another loaction with another name
Please help meto do this
Thanks & Regards
M.J Augustin
Certified LabVIEW Developer
(3,602 Views)
Reading file and make a copy of it to a new location are two different operations...!!
Well to make a copy you can use the function available in LabVIEW.
For reading from Excel file check:
How Can I Read Excel Data Into LabVIEW?
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,597 Views)
Thanks for the suggestion, but what i need is I ve created a template file to which data will be writing during the acquisition. The template contains logo field to put signature etc (static fileds).So during the data acquisition template will get filled but if it is not saved into another file next run it will get overwritten.so i want to save the file into another name automatically
Could you please help me in this
Regards
M.J Augustin
(3,570 Views)
Check attached VI, that might help you...!!
(3,566 Views)
