Save file to user's desktop
Hi all, just a simple question (I hope!)
I'm writing a program and I want it to save the output .txt file to the desktop. Of couse, different computers will have different directory paths to their desktop (I.E. C:/Documents and Settings/Bob/Desktop - the username will be different in all cases).
Is there a certain command you can use to tell this system that you're looking for the desktop, regardless of the rest of the directory path? If that makes any sense.
Thanks!
(4,474 Views)
Accepted by topic author robin533
Yes.Use Get System Directory in file IO under file constants.
LabVIEW 2012
(4,472 Views)
Thanks!
(4,467 Views)
