Save file without no prompt
Hello , i have a problem with creating new file, i need when new file is created without no prompt for user . File name is generated automaticaly with time string in name file see attached file. Thanks Smoke
(2,979 Views)
You simply wired the wrong terminals in the open file.  You need to build the file path and wire that input.  See attached fix (LV7.1.1)
Paul
(2,972 Views)
look at this modified version of ur VI
regards
Dev
(2,968 Views)
OK, problem was fixed, thanksSmiley Happy
(2,955 Views)
