Save for previous error on FPGA vi (LV2009 -> LV8.6)
Hi all,
I have an RT project i want to back save from LV2009 to LV8.6. When trying to save for previous, all FPGA subVI's are saved correctly but the top level FPGA vi returns error 1536:
LabVIEW:  To save a password-protected VI for a previous LabVIEW version, you must enter the password.
However, no VI is password protected :-s
All other top level VI's in the project referencing the FPGA VI also return this error.
I searched this forum but found no similar topic, so maybe i'm missing something
Can someone please help?
(3,818 Views)
Are you by any chance using mac?
(3,814 Views)
I am getting the same error. LV 2009 on Windows Vista.    There are only 4 VIs (FPGA Main, FPGA subVI, Host Main, Host SubVI) and a Shared Variable Library file.  The SV library file and on the FPGA subVI get copied into the new directory along with the LVbit file but nothing else.  I am not even sure what VI is having trouble on.
Joji
(3,774 Views)
Okay. I verified mine does the same thing. If I pull just the Top Level FPGA vi from the project then it Saves to Previous just fine.  I don't think it has anything to do with the code itself. But if it does, all I am doing is a very simple VI (see below)
Joji
(3,773 Views)
Ok. I figured it out.  If I remove the Wait (Ticks) Express VI from the diagram and readded it. Then the issue went away. Looks like a remnant of the LV 8.6 code is somehow not get loaded up correctly.
Joji
(3,760 Views)
