Save front panel as an image or pdf file
Hi all,
I have been wanting to save my front panel as a PDF or JPG but without using ctrl+P.
I was trying out the function: write to JPG, but how can I specify the path to jpeg file when no jpeg file has been generated yet? I don't understand.
(1,087 Views)
This is the name you want your picture to have, like using "saving as" function. If it already exists, it will be overwritten.
(1,057 Views)
It is asking me to select an image when I run it.
(1,048 Views)
That's the problem with attached images, you can't debug them. Is your path control perhaps empty? Replace the control with a constant with the path and name where the image should be.
(1,026 Views)
