Save front panels to electronic document
Is there some way to save LabVIEW VI front panels to a file in some format I can then import into a document? Some of the front panels are too large to copy & paste in MS Paint and besides, I like the quality you get when you print the front panel from LabVIEW. I need to integrate some front panel images into a tutorial document.
Sara
(2,382 Views)
Nevermind, strike that request. I found "Easy Print VI Panel or Documentation.vi" on the Report Generation palette and it does what I need.
Sara
(2,382 Views)
