Save histogram data to a ASCII file
I work on a LabView application which samples temperatures on a [c]FP. I produce a histogram by using the express histogram vi.
I don't know how I can save the samples (Y) it means the occurences in a spreadsheet file, because the histogram data are dyn. data.
Thanks for help.
Thomas
Thomas
(3,349 Views)
Hello Thomas
If you just want to save the y-values, just wire the dyn.-data to the normal "Write Spreadsheet"-function. Then it writes a line, containing the y-values.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,338 Views)
Thats it.
Thank you
Thomas
(3,327 Views)
