Save image and send to zip file
Hello
I am trying to think of a way to save an image from a plot and then save that as a JPEG or BMP file and send it to a zip file.
I want to loop it so everytime my program runs and it is finished, it will save automatically and add it to the zip file.
Any help is appreciated.
xxxMidna19
(2,500 Views)
If you create a reference to the plot and wire an invoke node to it you can select Export Image.  This will let you save the file as a BMP.  You can use the built in Zip functionality (on the File I/O Menu) to add the image to a zip file.
To print the whole front panel you can create a VI Server Reference and wire another invoke node to it.  Select Print > Panel to Printer.
(2,493 Views)
