Save in a variable an instrument handle out
I wanna create a sequence in teststand using labview step. the problem is the VI of my labview step has a function with instrument handle in and instrument handle out. How can I store those instrument handle out in a variable to be able to use that variable as the input of an instrument handle in in another VI and if it's possible wich kind of variable should i use in both labView and teststand.
Thanks in advance for your answer
Christelle
(2,578 Views)
You can use the Session Manager. There's an example (in 3.1 anyway), in the SessionMgr\Lv\LVDMM.seq.
(2,573 Views)
