Save string/numeric value
Hello!
How can i do for save a value of a variable so i can use it in future? I have an output string from a case structure moved by an OK botton. I want to save the string value when i press the ok botton...
Thanks in advance
GM
(3,959 Views)
Accepted by topic author gmazza
Just write the string to a text file.  When you want to use it later, read the text file.
(3,942 Views)
If you only need local use, save it in a shift register in your main process loop or just as a wire to the new use location.  Run the shift register wire through both cases of the case structure.  Replace its value in the button pushed case.
(3,923 Views)
You can use the Configuration File VIs. Take a look at the Help file and at the examples for these VIs.
Ben64
(3,909 Views)
