Save to ASCII/LVM in Sound and Vibration Toolkit limited to 100,000 samples
I'm taking about 400,000 samples at 50kHz sampling and I see the all the correct data in the wire leading into the Save to ASCII/LVM.  However, I noticed that the file actually only has the first 100,000 samples and then repeats the first 100,000 samples 3 more times to give me the expected 400,000 sample total.  This was confirmed by looking at the actual file and also first noticed when I read it out using the Load from LVM vi.
I
(2,375 Views)
Looks like your express VI is set to overwrite the file? Try setting the Close input to True. Maybe that will flush the file to disk.
(2,371 Views)
