Save to Previous Version Failure from 6.1 to 6.0i
I am building LabVIEW instrument drivers according to NI's template (which is in 6.1 format).
I built the drivers and used Save to Previous to save to 6.0, but 6.0 crashes when opening them. However, I managed to save the driver tree with Save to Previous down to 5.0 format. LV 5 opens them without crashing.
I cleaned them up in LV 5 so I could release in 5 and have them work in 5, 6, and 7.
However, LabVIEW 6i crashes when opening them even after I have rebuilt them with all 5.0 components.
I will include my LV 5 tree, if anyone can help.
Mark Eckdahl - Software Manager at Blue Max Systems
LabVIEW developer for 20 years
(3,301 Views)
Mark,
I was able to open your VIs in LabVIEW 6, but received many .cpp errors when trying to recompile them. I was able to open it in 6.1 and save it back to 6 as separate VIs, not as the llb.
I then recreated the llb, and am attaching it here. It was saved in LabVIEW 6.0
Zvezdana S.
(3,301 Views)
Awesome Zvezdana,
The library here still has the cpp errors with some of the files I opened. Perhaps you attached the wrong folder, I will follow your advice and see if I can do the same.
Thanks for the quick response and insight!
Mark
(3,301 Views)
