Save to Previous version LABVIEW 8.0 to 7.0
Can someone help me save this version to 7.0?
Thank you so much
Krispiekream
Message 1 of 10
(4,703 Views)
As much I know earlier version save is available from 8.0 and further.. not to earlier version ..
Message 2 of 10
(4,677 Views)
To my understanding, you can save it as far back as you have installed. So if you have 2009, 8.x, and 7.x installed you can convert between the three (1 version at a time I believe).
I'm sorry I can't help you out, but maybe they can help you out here
Cory K
Message 3 of 10
(4,673 Views)
you may like to read this .. previous version save
hope it helps
HS
Message 4 of 10
(4,670 Views)
hope it helps
HS
This makes it a little tricky to jump down several versions, but it is still possible (if functions arent only available in newest version of LabVIEW).
For example, to save from 2009 to 6.1 you would have to save in the following order:
2009 --> 8.0.x --> 7.1.x --> 7.0 --> 6.1
Instead of simply saving straight from 2009 --> 6.1
Cory K
Message 5 of 10
(4,662 Views)
I know that you cant go from 2009 to 7.0.
i have saved from 2009 to 8.0.
i need someone to have 8.5 or 8.0 to help me save to 7.0?
Can someone help?
Krispiekream
Message 6 of 10
(4,647 Views)
There is a thread dedicated to downconverting VI's
For future reference, there is alsoone to upconvert VI's.  You can find links to both on top of the LabVIEW Forum.
Tim Elsey
Certified LabVIEW Architect
Message 7 of 10
(4,639 Views)
Message 8 of 10
(4,621 Views)
Message 9 of 10
(4,596 Views)
muks wrote:
In 7.1
Has already been provided in the downconvert thread. Besides, the OP asked for 7.0, not 7.1. Smiley Wink
Message 10 of 10
(4,569 Views)
