06-23-2015 03:30 AM
Hallo,
I was using a c-RIO 9111, for creating and saving files in an external memory (using TDMS toolings in directory u:/).
Everything was working fine, but when Im trying to do the same in a cRIO 9066, looks like I´m not getting the right root.
In MAX>> Datatransfer I access to the u: directory, and I can see the folders ans files created, but when I do it directly in my PC with the external memory, its empty.
Looks like the cRio has an internal partition with that directory.....Could be that? How can I read the external directory unit??
Thanks for your help and best regards!!
06-23-2015 07:38 AM
Try using the List Folder function on the Advanced palette of the File I/O. Normally this is used to list files and folders in a directory, but if you provide an empty path as the input it will return the drives that are available. So for me the Folder Names when the path is blank is C, D, E, N, P, Q, R, T. These are the drives that are available. Maybe your USB is mounted as a different drive letter for some reason.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-23-2015 07:41 AM
Oh this is one of those new Linux chassis. You'll need to use a path similar to this.
/u/Example Folder/test.txt
According to this article.
http://digital.ni.com/public.nsf/allkb/65C685BD7EC10D6B86257D07004A9825
06-23-2015 09:34 AM
Thanks so much for your help.
I´m trying to create first a folder.
I was trying with /home/u (Error 1430 occurred at Create Folder in create_folder.v // Possible reason(s):LabVIEW: The path is empty or relative. You must use an absolute path.)
C/home/u I dont get any error, but when I look inside my external memory is empty. (if I see through MAX >> Datatranfer, i have the folder created correctly)
Looks like Im not using the right directory (but in any internal partition of the cRio).
I apreciate any idea, thank so much for your time
06-24-2015 01:44 AM
Have you tried another USB memory?
Jesús
06-24-2015 01:53 AM
On the other hand, what happens if you tried to create a dynamic path as shown on point 2 of this article? Is there any error? If so, which one?
06-24-2015 03:34 AM
Thanks for the answers,
Yes i was already testing with another memory and same behaviour.
I was also creating a file inside my memory to see through MAX if i can see it.
(MAX >> datatransfer) I attached the files it shows me.
I went through the folder "u/" but its empty....
