Save wavefromgraph data of format [f0,df & magnitude)into TDMS file
How to save Wavefrom Graph data into TDMS file including fo & df along with the magintude.
I am able to save magnitude alone which is not correct ,coz i have f0 & df also needs to be saved in order to calculate some values
pls see the below image which shows the i/p format to the wavefrom graph. Also pls do the needful help.  .
(3,059 Views)
Hi, check this link
Simultaneously Write and Read TDMS Data.......
https://decibel.ni.com/content/docs/DOC-7982
(3,038 Views)
