Save with options
I received the error message below when trying to save hierarchy into a new LLB file.  The initial message is "The following files have links to help files that are invalid. Open the files and fix the help links.
C:\Autoware Projects\U3 Evaluation\7000 Recipe Lookup.vi"  I do not have any HELP related links in my vi's.  I did not have any problems with this code in previous versions.  I also get this same message when trying to build the application into an executable.  Below are the additional errors from the build error window.
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at ABAPI Check Help FIles.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File.vi -> SDBEP_Invoke_Build_Engine.vi -> SDBUIP_Build_Invoke.vi -> SDBUIP_Build_Rule_Editor.vi -> SDBUIP_Item_OnDoProperties.vi -> SDBUIP_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.
NI-488:  Non-existent board.
(2,850 Views)
Hi rabbit,
Go to VI Properties (Ctrl-I) and pick the "Documentation" page.  You don't have anything in the "Help tag" or "Help path" blanks?  If you do, delete whatever is there.  If you don't, attach one of the VIs that is causing the problem and we can try to help you from there.
-D
(2,835 Views)
