Saved file size decreases with time
@M.A.A.M wrote:
For  DAQmx Configure Logging, I didn't understand well how to use it, i try to use it, but it runs once and the stop,Smiley Sad, I am sure that I didn't understood the functionality of it well, can you state me for some example ,.
You use the DAQmx Configure Logging before you start your task.  Then you just let your task run for the full time of your testing.  You do not need the inner loop to stop after 60 seconds.  Just let it do its thing until you need it to stop.
GCentral
Message 11 of 11
(603 Views)
