Saving 2D Array and Time into Spreadsheet
I have been working on a code that takes temperature values from a thermocouple data acquisition device. Basically, I had to convert the data (from the waveform) into a decimal string. I did this so I could insert it into an array with time. I was having trouble with this and this is the only way I could get it to work because the time is a string and the data is a double 2D array. However, the data is saved but the Channels and data are all in 1 row rather than being in separate columns. I need help fixing this, in addition taking advice how I can have 1 column just being time.
This is what it looks like: (the | represents a new column)
Ignore the NA it because I do not have a temperature sensor connected to that channel.
Channel 1, Channel 2, Channel 3, etc., Time |
72, 72, 72, NA, NA, NA, 1:00    |
72, 72, 72, NA, NA, NA, 1:01    |
I want it to look like:
Time  |   Channel 1   |   Channel 2   |   Channel 3  |  etc.
1:00      72.1                72.1              72.1
1:01       72.2               72.2               72.2
Here is my VI and an excel file that saved
(2,494 Views)
We don't have your hardware&drivers, so we cannot test your code.
I assume that you get a 1D DBL array with each iteration of the while loop which you want to append to the file as a new row. Who wrote this code? (looks like it was written 25 years ago with all these stacked sequences and sequence locals. Nobody does it anymore like that. 😮
Did you know that "index array" is resizeable? No need for 8 instances and no need for dynamic data.
personally, I would open the file using lowlevel functions before the loop, write the headers, then append rows in the loop, and close the file once the loop is done.
(2,464 Views)
See if this can give you some ideas...
(2,455 Views)
You can also do something like the following to replace your stacked sequence structure:
Here I take the clusters of "Type" and "Active" via an array (see FP comment) to a For loop and avoid the use of a Case Structure by using the Select node.
In the diagram above, there's nothing hidden - all of the necessary code can be seen at once (and without taking up a lot of space).
(2,440 Views)
