Saving Arrays to one Array, Arrays zusammenfassen
Hallo,
I have two arrays, f.e. "1 2 3 4 5" and "6 7 8 9 0", an I want to save them in one array like:
1 6
2 7
3 8
4 9
5 0
(two values in one line seperated by tab)
The "Build array" vi gives the following output:
" 1 2 3 4 5 6 7 8 9 0"
inkluding the strange Symbol "[]" (a square) and no linebreak. How can I handle this? I attached my original output.
Arno
PS: LabVIEW 7, answers in german, english or dutch
(2,771 Views)
Here you go. See attached.
Dave.
(2,771 Views)
Thanks Dave,
it works ALMOST. Look into the output file.
Arno
(2,771 Views)
OK, try this. It will only work if you are using numerics. Modify the %15e as required for your type of numbers.
Dave.
(2,771 Views)
