Saving Live Data on Command
Hi All,
I have a pretty simple concept that I'm trying to turn into a VI. I am measuring a voltage signal through a digital lock-in amplifier which sends the signal to my computer. I've successfully plotted the signal vs. time and have a working code that even lets my save this data.
Next I want to be able to save particular bits of my data, in real time, to a new file. For example, I will be measuring this voltage in real time while I change a parameter of the system that produces the signal. This should cause my plot to spike to a new voltage value and then remain at this voltage until I change the parameter again.
Is it possible for me to press a button and have LabView save the data that's gathered until I press the button again? Could I do this multiple times throughout the run that way I can have multiple data sets corresponding to multiple values of the parameter?
Thank you!
(2,590 Views)
Hi emullen,
The answer to both questions is YES!
(2,569 Views)
It's pretty common to use an event structure inside a while loop to look for button presses or value changes. You can use the timeout case of the event structure to update your data / graph.
To generate your filenames you can use "Format into string" with a format like "Parameter_%d.txt". Once you wire a numeric, for example 200, the actual output string will read Parameter_200.txt. If you are going to visit the same parameter value more than once in, then you will need some other unique specifier, like a timestamp.
(2,556 Views)
