Saving Multiple Waveforms to a Single Excel File
I would like to export the four LVDT waveforms to a single Excel file. In this Excel file, I need:
  • Two columns for each waveform: one for real time in seconds and one for displacement (from 0 to 5 mm).
  • The time column should reflect the time for each waveform, and the displacement column should show the corresponding displacement values.
    How can I achieve this in LabVIEW? Are there specific functions or tools I need to use?
Configuring Time Axis on the Front Panel
On the front panel, I am using waveform charts or graphs to display the waveforms. I want the x-axis (time axis) to show time in seconds, ranging from 0 to 60 seconds.
  • What properties do I need to configure in the chart/graph’s Display Format to achieve this?
  • Are there additional settings to ensure the time axis updates dynamically and consistently during runtime?
(1,048 Views)
Start with configuring convert from dynamic data to 2D scalar.  Data is currently 1D.
Run program, select edit, make current value default, and resave VI.  I can see the data you recorded if you save it as part of the VI.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(985 Views)
