Saving a 3-d array
Can I save a 3-d Array? How?  Thanks.
(4,357 Views)
You can save anything you want. What format do you want to save it as? A simple method is to simply use a Write to Spreadsheet File inside a for loop.
(4,356 Views)
So the array is 750 X 50 X 40. Save 750 2-d arrays then reconstruct as needed?  I guess I should have though of that. Thanks.
(4,351 Views)
Another method is to simply use the Write to Binary File.
Another method is to use XML using the LabVIEW XML schema.
Another method is to use XML using your custom schema.
(4,327 Views)
you can convert 2D to 1D, then use for loop convert 3D to 2D.
(4,319 Views)
And reopening the binary file should be rather quick, I would think.
Thanks.
(4,295 Views)
Actually, you don't need a loop. The Reshape Array function will accept a 3D array and spit out a 1D array in the same way.
(4,294 Views)
