Saving a Text data to a PDF file without using print option
I want to save a Text to a PDF file. I want to assign the path of the PDF file as a default one.
If I use Print options, then it ask for the file path at the run time.
Is there any method to save to a PDF file without using print option in Labview 8.2.
Raja
(2,994 Views)
This question comes up a lot. Did you try searching? It depends on the PDF printer driver that you're using. See here, here, here, ...
(2,984 Views)
I think all the link you gave doesn't have a solution for what the file name will be automatically save as.
for instant, you cant give it a name in labview and save to
*.pdf
SN_343432.pdf is what I want to save it as and not the predefined name given by PDFCreator and then later you have to rename them.
does that make any sense?
Krispiekream
(2,820 Views)
