Saving a Time Stamp In Memory and retrieving it
I would like to store the time stamp in Flash memory. The memory is 8 bit. So how would I store it in byte format to the memory and retrieve the memory, then put it back together to get the time stamp back...
thanks
(3,024 Views)
Where is this Flash memory you are trying to save to?  Is it built into your PC somewhere?  Some other device?
(3,016 Views)
a LabVIEW timestamp uses 16 bytes (or 128 bits) of memory. You will never store it in just 8 bits…
(3,010 Views)
What best you can do is consider some reference time and store the difference i.e. no of seconds. At the time of retrieval also you can do the same.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,986 Views)
