Saving all files/vi's & Max config. for another computer
I was wondering the best method to save all files/vi's/max config stuff so it will work on another computer. I'm not sure of the best way to accomplish this using L.V. 8.2
John
(2,523 Views)
There is no utility that automatically copies everything off one computer and onto another.  The best way is to export you MAX settings by clicking on File>Export. Then you can either copy all of your VIs over manually or create a project and use it to create a zip file. I hope this helps but post again if you would like more instruction.
Eric A.
Distributed I/O Product Support Engineer
(2,499 Views)
