Saving all projects files
@s.h._tech wrote:
Every time I save the projects a lot of files are saved (even if I only edited one) which takes about 1-30s. This makes fluent development impossible.
This typically points to circular and/or complex dependencies between VIs.  That makes it hard on the compiler, which will cause slow downs.  Otherwise, I have had many 100s of VIs in a project and the same times are non-existent.
I would first question the use of a Strict Type Def.  I might have 1 occaision where it was appropriate.  Almost always a normal Type Def is fine as I am not dealing with many GUI windows that are showing the same thing.
Message 11 of 14
(554 Views)
@s.h._tech wrote:
I activated
Tools>>Options>>Enviroment: General -> seperate compiled code from new files
Is this the right one? My LV is in German and sometimes I have trouble finding the right translation
That just sets the Seperate From Compiled for any new VI you create.  You can right-click on the project in the project window tree and select Properties.  In the dialog that opens, there is an option to set the Seperate From Compiled for new items.  Make sure that is checked.  And directly below that is a button to Mark Existing Items.  Select all of the files and click the Mark Selected Items button.  That will set the option for all of the VIs in your project.
Message 12 of 14
(552 Views)
My application consists of 1 Producer and many consumers. Each consumer has a 'lvclass' where all the data is stored. Every consumer has a least one 'Strict Typedef' which is also represented on the frontpanel of the Producer. I also working with queues and notifiers to communicate with the statemachines.
My code is definitely (needlessly) complex and maybe passes some unnecessary data around but hopefully not at this magnitude.
EDIT @crossrulez: With your instructions I found the correct option in the properties of the project. I continue working and report the behavior back
Message 13 of 14
(544 Views)
I have worked now for ~1day and also intentionally modifying my 'Typedefs'. So far the saving times are greatly reduced.
Thanks for the help
Message 14 of 14
(511 Views)
