Saving an 2D array to a text file
I have written a program in labview which does some particle analysis on an image. I have written a some C and compliled it as a dll to save a 2D array as a text file. (I used this this tutorial: http://decibel.ni.com/content/docs/DOC-1690).
This works fine until I transfer the program to another computer (it seems to want some other dll file associated with visual studio, which this other PC doesn't have).
I there an easier why to do this without using a dll file? I have attached the .vi file and the c code i was using. The .vi uses a black bmp image with white circles on it.
Jack
(20,736 Views)
Hi Jack,
Use the LabVIEW File I/O functions to write the data to file. From what I see in your C code you write the data in text format. "Format into File" is very similar to the C fprintf function you're using.
Check the LabVIEW help/examples for more information.
Hope this helps,
Daniel
(20,733 Views)
Ok thanks, I'll have a play. One of the reasons I did it in C in the first place was because I couldn't work out how to extract individual elements of the array and print them to the file individually (so I had some control over the formatting).
Cheers,
Jack
(20,730 Views)
Well then you should learn some LabVIEW basics first Smiley Happy
Good luck!
Daniel
(20,727 Views)
bluefocs wrote:
... I couldn't work out how to extract individual elements of the array and print them to the file individually
You could use the Index Array function :
Message Edited by Cory K on 02-04-2009 01:04 PM
Cory K
(20,703 Views)
What are the names of the 2nd and 3rd yollowish blocks? Can't find them at the moment.
(20,677 Views)
Hi bluefocs,
these are "build array" and "array to spreadsheet string" - pretty basic Smiley Wink
You really should learn the basics of LabView!
(20,668 Views)
