Saving and retrieve custom attribute of waveform from a .TDM file
I would like to save some custom attributes inside a waveform, save this waveform in a .TDM file and then retrieve these attributes from the .TDM file.
I can put custom attribute in the waveform, but when I read the .TDM file, the custom attribute disappeares. I sent an example VI which surely explains better what I try to do. The .TDM is save under "C:\measurement\toto.tdm".
Risotto
(2,612 Views)
Hi Risotto,
I think that the best way to show the possibilities is sending you an example VI.
The attached VI contains variouse ways to modify and read properties of a TDM file.
If you have any questions on this example, feel free to ask.
Stefan Henke
NIG
(2,587 Views)
