Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Saving changes to global variable
clueless
Member
06-02-2003
06:17 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
This is a real newbie question, but here goes. I want to edit values on a global vi, how do I go about doing that?
Globals.vi 29 KB
0
Kudos
Message
1
of 4
(2,894 Views)
Reply
Re: Saving changes to global variable
Shan
Active Participant
06-02-2003
06:40 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
1. Make your edits.
2. On the menu select Operate > Make Current Values Default (operates on all the controls) or right click on the control and select Data Operations > Make Current Value Default (operates on a single control).
3. Save the vi.
Tim
0
Kudos
Message
2
of 4
(2,894 Views)
Reply
clueless
Member
Author
06-03-2003
07:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks Shan. I knew there was a relatively easy solution.
0
Kudos
Message
3
of 4
(2,894 Views)
Reply
Shan
Active Participant
06-03-2003
09:32 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
BTW, that works for any vi, not just Globals.
Tim
0
Kudos
Message
4
of 4
(2,894 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
