Saving comma separated string to file in two column.
I have a comma saperated string how can I save it in a file in form of two column.
e.g.:
"a,1,b,2,c,3,d,4,e,5" suppose this is my string than I want to save it in an ASCII file as:
Name               Age
a                        1
b                         2
c                         3
d                         4
e                         5
(3,107 Views)
Hi vaibhavinegi,
convert your string to a 1D array of strings, then decimate to two arrays, then BuildArray to form a 2D array (or use ReshapeArray instead of Decimate and BuildArray). Then save your array as needed…
(3,101 Views)
Something like this should work for you.
(3,086 Views)
