Saving data at a slower rate than I want my VI to run at?
Good morning everyone.
I have a VI that scans hardware for data. I need this process to run at around 0.1 to 1KHz. I only want to store this data at a rate of 1Hz though.
I can't figure out how I can get my data into the .txt file at a rate of only 1Hz without slowing down my whole VI to 1Hz.
I have attached an example of what I'm trying to do. I am using random number generators in lieu of my data acquisition code to simplify things a bit.
Thanks!
Message 1 of 11
(3,343 Views)
Hi lavid,
you could decimate your data to 1 Hz!
When you get data at 1kS/s you would get the mean of 1000 samples (or just pick one sample out of 1000) for saving…
Message 2 of 11
(3,336 Views)
Hi GerdW 🙂
I am saving my data in a string into a txt file. The decimator doesn't work on the date and time I want to be saved with each row of data unfortunately.
Hmmmm
Message 3 of 11
(3,310 Views)
Hi lavid,
one note: you can decimate before converting to string…
Message 4 of 11
(3,281 Views)
Right, but then my data is decimated and my date and time string still saves at 1kHz and my .txt data file gets all discombobulated :I
Message 5 of 11
(3,273 Views)
Obviously you decimate the date/time as well.
Message 6 of 11
(3,271 Views)
I thought I couldn't decimate a string...?
Message 7 of 11
(3,267 Views)
Like GerdW said, you can decimate before converting to a string, or if you have an array of strings you can decimate that array.
Message 8 of 11
(3,260 Views)
Hmm... Lets see you want high speed data acquisition and low speed data recording.
Isn't that by definition a Producer Consumer architecture?
=== Engineer Ambiguously ===
Message 9 of 11
(3,256 Views)
I'm not certain I understand why you are having such difficulty with the idea of decimation.  Does this Snippet make sense to you?
Bob Schor
Message 10 of 11
(3,228 Views)
