Saving extremely large images with IMAQ
I have a program that takes several hundred 2048x2048 images and puts them all together into one giant matrix.  When I save the image with IMAQ Write to File 2, i get error -1074396154 "Image Is Not Large Enough for The Operation".
I have followed the instructions here to no avail.
Once that is figured out, I assume this is going to take forever and a day to save to the disk, is there any way possible to speed it up or save-as-I-go?
Thanks in advance
(3,466 Views)
Are you using any imaq extract? Have you defined a seperateand unique imaq create.vi and connected it to the image dst? Can you post a screen shot of your vi?
(3,430 Views)
No imaq extract.
Here's a screencap of the relevant portion
(3,412 Views)
After doing some research, it seems like I may have to incorporate BigTIFF into the program.
How do I import this functionality into LabVIEW?
(3,405 Views)
This thread might help someone answer my question, someone has previously converted libtiff to LabVIEW.
http://forums.ni.com/t5/LabVIEW/Labview-libtiff-implementation/td-p/929843/page/4
Will the posted solutions above allow me to use BigTIFF?
Thanks...
(3,401 Views)
The error you're getting looks like it might be coming from the Array To Image VI, not the Image Write VI - you can check using highlight execution.
If your image is larger than 4GB, then libtiff won't write it (though it will if your image is larger, but you use a compression to make it smaller on disk).  I'm not sure about the IMAQ TIFF.  I've written my own wrapper around libtiff, but haven't seen one for bigtiff.  Once you're getting images that large, perhaps another format would be better and faster anyway - for example writing to an HDF file or even a binary file directly from your array.  These options also mean you don't need to copy it all into the IMAQ image.
(3,393 Views)
