Saving file error
Hi Bombboo,
why can't you? There's an "append?" input for that function...
Message 11 of 17
(911 Views)
I already tried to use the spreadsheet file. as the attachment.  I already created the excel file to receive data from the programming. but it's not working. Could you please try it with your computer or add anything to make it work??? It's pretty inmportant!!
Thank you
Message 12 of 17
(902 Views)
Hi Bombboo,
your VI is working as you have programmed it to work... (See attachment for a moderate cleanup.)
But:
- You gave "Date/Time\tChannel\s0\tChannel\s1\n" as delimiter. And LabVIEW is using just that as delimiter between your numbers. When you need something different you should program it...
- When you give "Date/Time\tChannel\s0\tChannel\s1\n" (probably) as header line you should use real tabs instead of "\t". Switch the string to slash code display and correct it...
Message 13 of 17
(898 Views)
Thanks for helping me but it's still not working when I opened the excel file. I attached the picture of error. Thanks
Message 14 of 17
(893 Views)
Did you actually change what you had as the delimiter? Gerd did not do this for you.
Message 15 of 17
(889 Views)
I tried to press "tab" on the keyboard but nothing happened on the string tab
Message 16 of 17
(886 Views)
It's not supposed to do anything. As Gerd mentioned, use the tab constant on the string palette.
Message 17 of 17
(882 Views)
