Thanks, John. Right now I'm saving a whole bunch of images on an external drive and then post-processing them into an AVI file on the host PC. However, I am running into a frame rate problem. I can only get a maximum 15fps from a 60fps camera. After examining my setup, I believe I miscalculated my throughput and something is getting overloaded. I know this is an amateur question, but for a Firewire400 port, it's 400 mega-bits per second, not mega-bytes, correct? That would equate to 50 mega-bytes per second, correct? I just want to make sure I'm getting this right. Thanks!
