Saving image sequence from Vision Acquisition Express VI
Krispiekream,
Thanks, but the saving goes quickly enough, I was just having trouble being able to control when saving starts and stops using a button.
muks,
The trick was changing the button to switch when pressed.  When I did this for the Save On/Off button on the VI with the nested while loop that I posted yesterday, the saving works great.  The Stop button doesn't seem to do anything unless the Saving button is on, and the Stop Imaging button stops the acquisition, but causes the Imaging Number and Frame Rate indicators to shoot up to unrealistic values (>10000).  But at least the saving control works well, as I can always stop acquisition by stopping the VI.
I did try the case structure inside a while loop as you suggested.  The saving control works, but for some reason the files saved are empty - turning saving on must turn the acquisition off.  But regardless, I'll stick with the nested while loop.
Thanks for your help.
Message 11 of 22
(3,561 Views)
I dont get that. Can you post the screen shot?
Message 12 of 22
(3,542 Views)
Hi jman1,
Looking at the block diagrams you've posted so far, the reason your acquisition stops when aaving begins is becuase you have data dependency between the loops.  In other words, in LabVIEW a loop will only send its outputs once the loop has finished.  Therefore, your acquisition must finish before you can save with the architecture you have presented.
Take a look at this community example:  Saving Multiple AVI Files from USB Grabs.  This uses and button's value change event to determine whether the images will be saved.  Feel free to download and modify it too.  You will want to replace the USB IMAQ VIs, as they are outdated (and replaced by IMAQdx, which supports USB cameras as Vision Acquistion Software 2009).
Message 13 of 22
(3,530 Views)
muks,
Here is my attempt using case structures.  I haven't attempted to fix it since Kristen's advice.
Kristen,
Thanks for the explanation.  I'll attempt to modify that example for my application.
Message 14 of 22
(3,520 Views)
Yup, that is what i suggested. Working now?
Message 15 of 22
(3,500 Views)
It still stops imaging when saving begins.  It might be just an incorrect setting in that particular Vision Acquisition Express VI.  The saving/imaging works fine when I use an imaging while loop inside of a saving while loop, as you originally suggested, so I'm going to stick with that for now.
Message 16 of 22
(3,483 Views)
My personal view is dont use an express vi. Use your own simple sequence of init-acquire-stop. Atleast this way where you want the stop to be and correctly wire it.
Message 17 of 22
(3,473 Views)
I saw your post and I'm having the same problem. I'm really new at LabView so I was wondering if you could send an attached version of the VI so I know exactly where the functions are and what they are called.
Thanks in advance
ffsalik@millikin.edu
Message 18 of 22
(2,802 Views)
hello,can you explain to me please the different composants that you use in this VI with their names.thank you.
Message 19 of 22
(2,176 Views)
In addition to the Vision Acquisition Express VI, here are the names of the other functions they used. Ultimately, their code is appending the loop iteration onto their chosen file path in order to save each acquisition with an incremental file name.
Message 20 of 22
(2,167 Views)
