Saving multiple numeric indicators
Hi all,
Im new to Labview and know there is a simple way around this problem Im having.  I cannot seem to save more than 1 numeric value from my numeric indicator using the Write measurement file.  Im wondering what a simple code might look like, thanks in advance,
(2,787 Views)
Really hard to tell you what to change without seeing what you have done. Either you need to place it inside you loop or make sure you build an array to pass out of the loop.
Please spend some time and take LabVIEW 101.
(2,774 Views)
