Saving one frame at a time?
Cheers!
I am using Low-level Grab Raw Data.vi example from NI-IMAQ. I want to save one frame at a time and then set the file position to end (and maybe add some mark that I recognize where the next frame begins). I know that it copies the raw data of the specified frame into Image Data Array. But does it write (in this example) data of one frame to disk and then set file position to end? If not, how to modify it?
How does changing number of buffer affect? I mean if I increase it >1 does it affect to number of frames to write per one iteration time of while loop?
I have Pixelink PL-B741F-BL camera. http://www.pixelink.com/products_info.asp?productcode=PL-B741F-BL&f-category=CMOS%20Imaging%20Module...
Kudos for good help!
Jick
Message 1 of 1
(2,662 Views)
