Saving report generation word file to a previous version of word
hello everybody,
well, the problem is quite simple.
on the computer of my bench I have office 2007, when I save a report generation word file it saves it from the template to a word 2007 file. file which is unreadable from a word 2003.
Is there any option on the report generation toolkit that allow me to save this file to a previous version of word like we do when we do save As on Word 2007 ?
thanks for your answer...
(2,685 Views)
I don't really know the exactly answer to your question about an option to save to a previous versions of word. But you can program it because the Save Report to a File.vi accept both ".doc" and ".docx" extensions. If you use the ".docx" extension or just the file name without extension (in the File Dialog express vi, for example), you will open the document only with Microsoft Office 2007. If you use the ".doc" extension, you will open the document with Microsoft Office 2003 and with Microsoft Office 2007 (in compatibility mode).
Let me know it this tip helped you.
(2,648 Views)
